Overheating after new pump
Old Apr 15, 2019 | 01:56 PM
  #21
ZEN357's Avatar
ZEN357
Sounds to me like it's a bad pump right from the get go.
Old Apr 15, 2019 | 04:04 PM
  #22
Chunx89's Avatar
Chunx89
Replaced it with he new pump and this is what I’m getting after trying to burp it for 30 minutes
https://imgur.com/a/SA2y4Xe
tomorrow after work I’m going to take the thermostat out and fill the block up all the way. I already took the stat out and drilled the hole in it. So this is what I have going on so far.
replaced pump with clutch
radiator gets so hot it can melt your skin
after burning for awhile the water looks like it starts to boil
after it looks like it’s “boiling” as soon as I turn the truck off the thermostat shoots water 2 feet in the air. During all of this my truck is only running at 200-205. It only runs hotter if I put the radiator cap back on
Old Apr 15, 2019 | 04:14 PM
  #23
The only time I have seen that kind of problem, is when there was a blown head gasket......
Old Apr 15, 2019 | 04:29 PM
  #24
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
CALLED IT! sorry OP
Old Apr 15, 2019 | 07:59 PM
  #25
AtomicDog's Avatar
AtomicDog
Sounds like you may have run that old pump too long and caused some engine damage. If the cooling system is full of coolant, you can connect a coolant pressure tester onto the radiator opening. If pressure is building on the gauge of the tester quickly, its highly likely that you have a blown head gasket.
Old Apr 16, 2019 | 09:17 AM
  #26
99DR's Avatar
99DR
Yup! If it's bubbling at 200 degrees, time to confirm the head gaskets...
Old Apr 16, 2019 | 11:46 AM
  #27
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I always turn the heat on when burping so it gets the air out of the heater core. I also rev the engine a bit. This sounds like a head gasket, I'd do a compression test on all the cylinders and record the numbers. I'd do a pressure test too on the cooling system. AZ/O'Reileys have the tester to rent, to get a complete picture of the cooling system and what needs repaired.
Old Apr 16, 2019 | 04:15 PM
  #28
Chunx89's Avatar
Chunx89
I did a block test on it today, and the dye stayed blue.
i tried it with the engine cold, warm, then also when it was running hot. I also tried it with the engine at 2k rpms. The engine oil is clean, nothing on dipstick and this thing never showed signs before that it could be a head gasket.
Im stumped with this one, STUMPED. I’m gonna fill the block with coolant today hopefully and see if that works. The truck still runs great if I take it around the neighborhood before it gets hot.
Propellers for water pump are in right direction, the fan belt is routed the correct way and the fan is blowing towards engine. I’m heading towards my tensioner being no good, it’s always made a little noise but with the old pump that was worn out I’m thinking it was powerful enough to spin a old water pump but maybe can’t keep up with a new pump.
Old Apr 16, 2019 | 05:48 PM
  #29
Chunx89's Avatar
Chunx89
Today I finally got the coolant to suck down finally. It was stuck at 200 then I walked around the truck to look at coolant and it sucked all the coolant down, unfortunately sucking more air in too. So I’m getting somewhere, it’s doing it again but it’s definitly showing signs of air in system.
Also my tensioner is screaming all of a sudden, and my AC compressor took a dump on me today. Clutch blew up, what a past couple of days
Old Apr 16, 2019 | 06:07 PM
  #30
MoparFanatic21
When it rains it pours :b make sure to turn the heater on while burping it
