Gear Shift Indicator
Old Dec 6, 2022 | 04:41 PM
gabriel mp's Avatar
gabriel mp
hello. (this comment is translated, there may be an error) how can I remove the plastic knee protector, I have removed the 3 screws that it has underneath, but when I try to remove the piece I feel that I need to remove something, it has a little movement but it is fastened, and since I know that the plastics of these years are flimsy and weak, I am afraid to pull hard.
Is there something else holding it or some technique to get it out?
(and removed the clouster too)
Old Dec 6, 2022 | 04:43 PM
gabriel mp's Avatar
gabriel mp
¡No hay problema! El plástico de la columna de dirección tiene que salir. Y quite el protector de rodillas (pieza debajo de la columna de dirección). Si tiras de él (suavemente) y ves el indicador rojo, es probable que esté roto en alguna parte.
Old Dec 6, 2022 | 07:36 PM
What are you driving?
Old Dec 9, 2022 | 01:14 PM
gabriel mp's Avatar
gabriel mp
dodge ram 2500 4x4 1998, V8 5.9
I want to do what the guy above says but the (knee protector "I don't know what it's called") panel that is under the steering wheel does not come out easily, and my question is, do I have a screw that I am missing or some trick?
