Gear Shift Indicator
Old Apr 24, 2019 | 11:36 PM
ZWymore's Avatar
ZWymore
Default Gear Shift Indicator
Today I bought my first truck, got a steal on it (hopefully) I bought a 2001 Dodge Ram 1500 with only 64k miles for $900. The vehicle does have some issues but I think If I can get these issues fixed it’s a good deal. Here’s the issue that I want to fix first, but I do not know anything about fixing vehicles. The first thing is the gear shift indicator. I am not sure if it’s a LED light on this model or a needle. However my truck is completely missing this. Any advice? Thanks in advance
Old Apr 25, 2019 | 12:16 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Can you post a picture? It should be in the lower right hand corner.
Old Apr 25, 2019 | 12:20 AM
ZWymore's Avatar
ZWymore
Old Apr 25, 2019 | 03:26 AM
DerTruck's Avatar
DerTruck
It's not LED and not really a needle, there is a red slider behind the holes underneath the lettering. Hard to tell because your picture was taken at night but it looks like there is a red marker below "P". If it doesn't move when shifting there is a short cable going to the shift lever that is either unhooked or broken.
Old Apr 25, 2019 | 03:28 AM
ZWymore's Avatar
ZWymore
There is no slider under the p I looked. I thought it was odd.
Old Apr 25, 2019 | 09:23 AM
MoparFanatic21
Take a look ah the cable even give it a gentle pull and see if you see the indicator.
Old Apr 25, 2019 | 10:24 AM
ZWymore's Avatar
ZWymore
Ok how do I get access to that cable? And thanks so much for your help so far
Old Apr 25, 2019 | 10:51 AM
MoparFanatic21
No problem! The plastic on the steering column needs to come off. And take the knee bolster off (piece below threw steering column). If you pull it (gently) and see the red indicator it is probably broke somewhere.
Old Apr 26, 2019 | 04:19 PM
ZWymore's Avatar
ZWymore
Thank you with your help and some guidance from someone I know I was able to fix this the wire was disconnected and it was dirty so we cleaned it reinstalled it and everything was good
Old Apr 26, 2019 | 05:14 PM
MoparFanatic21
You are welcome it's a very simple setup
