Need help with 46re trans
Old May 5, 2019 | 03:15 AM
Azboyinmi's Avatar
Azboyinmi
Default Need help with 46re trans
1996 ram 1500 sport.
2wd
5.2l
Auto.
Bought the truck from a friend, when he purchased the truck the motor was junk.
He pulled a low mileage 5.2 and trans from a 97 sport 2wd, and started I stalling it.
Winter closed in and the snow made it so be couldn't finish.
I just bought the truck off him for 750 and today I started hooking everything up.
Instantly found a problem.
The connector on the top of the trans is only a 3 pin connector, the trans he pulled out of this truck had an 8 pin connector.
What does that mean? Will this trans not work?
Yes I checked the tags and ran the codes and it is the right trans.
I have access to the old trans.... Can I just swap the valve body over and call it good?
Do I have to swap the torque converter too?
Has anyone delt with this issue? I need help, this truck is supposed to be running and driving and road Worthy by Monday night.
Any help would be really appreciated. Thx guys
Old May 5, 2019 | 07:10 AM
If the trans that got installed is a 3 pin, it is not a 97 trans. That's a 46RH, and some VERY early production 96 trucks got 'em, but, anything newer should be an RE. (with the 8 pin) You could make it work, but, the PCM is going to whine about trans sensors that aren't there.
Old May 5, 2019 | 11:10 AM
Azboyinmi's Avatar
Azboyinmi
What if I swapped valve body?
Old May 5, 2019 | 02:06 PM
Nope. Won't work. The trans body castings are different. No mechanical governor in the newer one, so, I would suspect passages will be different as well.
Old May 6, 2019 | 07:44 AM
Azboyinmi's Avatar
Azboyinmi
So, I found out the guy lied to me about what year the eng and trans came from. They're actually from a 95. He was my coworker at the auto salvage yard I work at, you'd think he would know how to look up interchange. Luckily my boss is gonna let me get the original trans back
