U Bolt Flip Kit reccomendations?
Old May 16, 2021 | 11:24 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by pilsbury88
For anyone using the search function in the future, i ended up ordering a set of u bolts, nuts, and plates from WFO concepts. I'll attach a copy of my receipt. Of course, prices may have changed since then. The parts weren't listed on his website so i called and he admitted he had many things that were not yet on the site, but he did stock everything i needed. The bolts were extra long, which would be great for a lifted vehicle but i just wanted to make sure i wasn't coming up short. After torquing them in place with loctite i cut off the excess. Years later, all is still peachy.
Did you do a u bolt flip?
Old May 17, 2021 | 05:01 AM
pilsbury88's Avatar
pilsbury88
Yeah 👍
Old May 18, 2021 | 01:53 AM
Ugly1's Avatar
Ugly1
These look pretty rugged. https://www.ramchargercentral.com/th...plates.134018/
Old May 18, 2021 | 09:05 PM
aresf11's Avatar
aresf11
When I had to do mine (I'm in MI, so I feel your pain being in the rust belt), I used 7" C-channel and just bought 5/8" U-bolts from a local heavy truck repair shop. I think they were $12 per bolt and included washers and nuts.
I did a writeup and posted here. Should have all the info you need: https://dodgeforum.com/forum/2nd-gen...-in-2wd-2.html
Old May 19, 2021 | 08:43 PM
Keith_L's Avatar
Keith_L
Alright so I just wasn't incredibly impressed with the options out there, although I guess I just like building stuff anyway even though I arguably don't have the time.
The OEM plates gain a great deal of rigidity from having vertical surfaces or breaks not only at the ends but in the center ---er at least on Fords that are already "flipped". For the aftermarket breaking the ends is easy but you need some serious dies to stamp out something like a Ford plate.
My point is that I feel even 3/8 w.t. is insufficient without bends both at the ends and around the center pin. The proper torque on 5/8" u-bolts is really trying to wrap those plates around the spring. Doesn't mean I'm right, it's just my opinion as a fabricator.
Thus, I used 1/2" plate. Lacking the ability to brake this, I slit with the bandsaw, bend to roughly ~45* and fill the resulting gap with weld. Doesn't mean it's a good way to do it, it's just how I do it (I've done this before)
Drilled in the mill
Slitting in bandsaw
Fully slit
Bent
Welded up at 22/450 with .035
Ground down - forgot to hit the holes with a c-sink!
Old May 19, 2021 | 11:12 PM
Ugly1's Avatar
Ugly1
Those are the winners. Nice.
Old May 23, 2021 | 12:40 PM
Keith_L's Avatar
Keith_L
So even though this '98 has spent its entire life in the arid Four Corners, it still had a similar issue to that which @aresf11 encountered in his link above: eroded axle tubes. I find it curious that the spring plate was in great shape but was filled with what ONCE WAS the axle tube.
I was simply uncomfortable with how the u-bolts interfaced with the eroded tube -- IMO they would never hold torque. So I welded up the tube and sanded it down. Since this was all by eye the tube radius is still less than perfect but is 99% better AFAIC
Not great
I'm not comfortable trying to pull the u-bolt to that
Oddly the spring plate is mostly unaffected. I chipped out a lot of the rust deposition before this shot.
Not pretty but it doesn't need to be as it gets sanded down. Rusty metal often makes for boogers.
Much better. What little daylight is visible will hopefully close up after torquing and re-torquing.
Trying to work out an upper overload system with the 1/2t 2.5" leafs. Thus far it's......an experiment
Old May 23, 2021 | 01:18 PM
That top leaf isn't going to do anything, aside from play spacer for the mounting plate.
Old May 24, 2021 | 09:22 AM
Ugly1's Avatar
Ugly1
Its a droop limiter for when he's doin 100mph through the whoops down in baja.
Old May 24, 2021 | 04:42 PM
Ok, that works.
