No turning at low speeds and u jiont issue
Old May 16, 2019 | 02:24 PM
lmbarrels's Avatar
lmbarrels
How do you know they have cracked? I have good oil pressure and she doesn't use oil
Old May 16, 2019 | 02:27 PM
It'll leak coolant. Cracks go into the water jacket.
Should be able to find some good pics on google image search for where the 53 is located. Quick and easy check. Even if you have one, I wouldn't worry about it unless/until it becomes a problem. Either way, make sure you keep good coolant in it, and that it will protect you down to however cold it gets where you are.
Old May 16, 2019 | 02:37 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I was also told they have bearing failures bur that could be wrong.
Old May 16, 2019 | 02:42 PM
HeikIlm's Avatar
HeikIlm
U-joint has inner C-clips, should've come whit them. Install those and cups should stay in place.
IIRC, 53-block was problem with 24 valves, not 12 valves.
Old May 16, 2019 | 02:46 PM
HeikIlm's Avatar
HeikIlm
Idle speed adjustment. http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old May 16, 2019 | 03:41 PM
lmbarrels's Avatar
lmbarrels
Yeah the one I was sold (u joint) did not have those clips, darn parts guy
I am going to try Napa and see if they have one.
Otherwise I have to order on line
Old May 16, 2019 | 09:45 PM
Moparite's Avatar
Moparite
Look it up and get the spicer part # and go from there. They will probably try to sell you some other manufacture.
https://www.expert.dana.com/expertforms/dek350.aspx
Old May 17, 2019 | 03:52 AM
DerTruck's Avatar
DerTruck
Did you check that the front axle isn't locked up from a differential failure ? That could explain the turning problems and the blown u-joint as well.
Old May 17, 2019 | 08:48 AM
lmbarrels's Avatar
lmbarrels
How would I do that and would it still drive fine if so?
Old May 17, 2019 | 10:20 AM
MoparFanatic21
Jack the front up and try to spin the drivers side wheel. Also no
