99 to 95 5.9 gasser motor wire harness swap?
Old May 25, 2019 | 09:13 PM
Robert Zunker's Avatar
Robert Zunker
Default 99 to 95 5.9 gasser motor wire harness swap?
Currently sitting with a 99 1500 ram, with the 5.9 gasser. Blew it up last winter, and I bought a 95 5.9 gasser to replace it. Curious if I am able to swap the 99 harness to the 95, and would it work?
Old May 25, 2019 | 10:13 PM
Not easily. A LOT changed from 95 to 99. You would basically have to replace all the wiring in the cab, and under the hood. You would also need to swap the dash. And if it's an auto trans, it gets even more complicated....... You can swap JUST the motor though, just make sure you swap intake for the correct year, and use the sensors for the same year wiring harness.
Old May 25, 2019 | 10:56 PM
00t444e's Avatar
00t444e
Are you talking about using the 99 harness in the 95 truck or using the 95 engine in your 99 trucks and wiring harness.
Old May 26, 2019 | 05:22 PM
Robert Zunker
Using it in the 99 harness on the 95 motor in the 99 truck.
Old May 26, 2019 | 05:25 PM
Robert Zunker
So what you are saying if i take the existing trans and transfer case in the 99 truck and pair it withe the 95 motor i should be able to use the 99 wiring harness?
Old May 26, 2019 | 05:26 PM
Robert Zunker
Old May 26, 2019 | 05:43 PM
What exactly are you trying to do? If you simply need a motor to drop into a truck, those swap over easy. All you need is the correct year sensors/manifold on the truck. (95 will have EGR, 99 won't. older motor has two temp sensors, other one has only one. and those are about the only differences, aside from the sensors, which you can easily swap.)
What is the end goal here? Which truck do you want to actually drive?
Old May 26, 2019 | 05:49 PM
Robert Zunker
I want to drive the 99. SOOOO if i take intake manifold from 99 and trans and tranfer case and pair it with the 95 motor am i able to use the 99 wire harness? Thats is the question I need an answer for. Very new to swaping.
Old May 26, 2019 | 06:22 PM
00t444e's Avatar
00t444e
Yes you can do that.
Old May 26, 2019 | 09:58 PM
Take the cam sensors from under the distributor cap as well. I think the connectors changed at some point.
