Loss of power
Old May 31, 2019 | 08:30 PM
4x4truck's Avatar
4x4truck
Default Loss of power
Hey there was wondering if anyone had any information that might help out. I've got a 98 ram 4x4 5.2l and when I got it I had to put a new ecm in it, ordered an ecm programmed for the trucks vin installed it and the truck ran, after I cut off the exhaust that was rotten just before the cat(between cat and manifolds) ever since the truck wont run right (no power Boggs down) I've changed plugs, wires, two fuel injectors and still nothing. I can drive well in reverse and and 4x4 low but nothing else. Does the truck have to have the full exhaust on it to run properly or is there maybe a transmission problem or possibly something else? Thanks
Old Jun 1, 2019 | 06:54 AM
Moparite's Avatar
Moparite
What did you replace it with and did you keep the 02's?
Old Jun 1, 2019 | 07:03 AM
4x4truck's Avatar
4x4truck
I havent replaced it with anything, was going to leave the exhaust off but if I have to have it I will get one, I put two new 02 sensors in and they're just hanging(not in any pipe) do I have to have the cat and everything installed with 02 sensors in pipe?
Old Jun 1, 2019 | 08:15 AM
See if it runs better with the O2's disconnected..... Having the front O2 sensor just hanging is really going to confuse the PCM.... It is ALWAYS going to see far too much oxygen, so, it will dial back fuel accordingly...... which won't make a difference, so, it will dial it back even more.... etc.
Old Jun 1, 2019 | 09:29 AM
4x4truck's Avatar
4x4truck
I didn't have any in it and same thing I went a grabbed them and put them in just to see if it would change anything and it didn't .
Old Jun 1, 2019 | 10:17 AM
How's fuel pressure?
Old Jun 1, 2019 | 12:49 PM
4x4truck's Avatar
4x4truck
Havent tested it but there was lots of fuel when I changed injectors, one was leaking when I put fuel rail back on spraying fuel everywhere I changed the o ring and its hasent leaked since
Old Jun 1, 2019 | 01:12 PM
Disconnect the battery for half an hour, then try it again. See if anything is different.
