Pic request // 35s on stock wheels
Old Jun 21, 2019 | 07:42 PM
rebeltaz83's Avatar
rebeltaz83
I was insulted when he said that a second gen 1500 has its but he could be new
Thought I was in the third gen section, my bad. We all make mistakes.
Old Jun 21, 2019 | 07:53 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Hey no biggie, I've done it so many times I've lost track
Old Jun 21, 2019 | 08:20 PM
rebeltaz83's Avatar
rebeltaz83
Lol, I don't always post in the wrong section but when I do I make sure it's non sense.....dos Equis 😁😁
Old Jun 24, 2019 | 10:27 PM
itsfusion's Avatar
itsfusion
Originally Posted by Ramman18
Wow, haven't seen this much misinformation for years. You can "fit" up to 37s on the oe 16x7 wheel. But you're gonna have to decide how much rub you can deal with and how often you want to replace tires because they will wear terrible. The largest that tire mfg recommend for 7" is 265-75/16 but you can run 285 or 295 depending on brand. I've used three different 285s now and all were slightly different size and wore uniquely. Also seen plenty of 295, 305, and 315 running around on stock wheels. The proper setup is at least 16x8 with 5" lift and centered axle for 35s. But Lord knows nobody really follows that. You'll have to decide what you want based on usage and budget then find a tire shop to install beyond specs. I've never had a problem with a shop installing larger tires but some have.
And what the heck??? IFS???? What planet is this guy from? All 2nd gen 4x4 trucks are solid Dana's, 44 and 60. Sheesh.
Hello! Sorry for such a delayed response. This post was really helpful for me. Final question, So will a 5in lift, 16x8 wheels, and 35s cause rubbing? Also, I'm wondering what offset I should be aiming for, because a lot of the 16x8 wheels have 0 offset. Would that cut it? I'm not trying to go for a super aggressive build with wheels sticking out, but rather a good looking, more modest off-road machine. However I don't want any rubbing. the RC lift I want recommends 4 inches of backspacing but says nothing about offset.
Old Jun 24, 2019 | 11:25 PM
HeikIlm's Avatar
HeikIlm
Basically, on a 8" wide wheel the 0 offset almost equals 4" backspacing, but actual BS number is 4.2ish.
Old Jun 24, 2019 | 11:57 PM
itsfusion's Avatar
itsfusion
So then would a 16x10 be more suitable for my build? At least to meet the requirements and not have any rubbing?
Old Jun 25, 2019 | 11:32 AM
Ramman18's Avatar
Ramman18
Zero backspacing is perfect as I understand it. Most aftermarket wheels are going to look good and not rub. It's the stock wheels that are the problem. Also, the new control arms will be thinner and round tubing so they help with the added clearance too.
Old Jun 25, 2019 | 02:19 PM
And some lift kits even come with lower control arms specifically designed to give you more clearance. Of course, they charge for that feature accordingly.
Old Jun 25, 2019 | 10:19 PM
OklahomaDave's Avatar
OklahomaDave
Currently running 315/75r16 Firestone MTs (almost 35s) on stock rims with a 3 inch lift.
Tires rub a little on control arms at full turn. Rubbing is not a big deal. Will only turn that hard at low speeds in and out of parking spots.
Old Aug 5, 2019 | 06:58 AM
V10ram2500's Avatar
V10ram2500
Default 35s on stockers
*disclaimer* I don't even know if this is possible, I recently bought a 2001 1500 and I am wondering if I can run 35s on the stock wheels. I plan on doing a 5 inch RC lift and a gearing upgrade. If anyone has any pictures I'd really appreciate it.
the red and white one is on 35s
