Rebuilt 46re transmission not going into gear
Old Jun 22, 2019 | 04:05 PM
InkedUpBadBoy's Avatar
InkedUpBadBoy
Default Rebuilt 46re transmission not going into gear
I have a 98 Dodge ram 1500 4 x 4 with a 46RE transmission that I just had rebuilt and I installed it myself. The problem I’m having is it’s not catching into gear or park or any drive first or second but it’s staying in neutral that I believe I’m trying to figure out where the neutral position is and how to set up the drive linkage or if there something else wrong
Old Jun 22, 2019 | 09:10 PM
Crawl under the truck, disconnect the shift linkage, and move the lever on the trans by hand. (block the wheels first please.....) Can you feel the detents as you move the lever?
Old Oct 20, 2023 | 12:37 PM
shzdow's Avatar
shzdow
sorry to bump this, but im running into the same issue. just rebuilt everything on my 46re. installed it and triple checked everything. when started up, the collomb shift cycles through all gears but none do anything at all. the engine will stall out in reverse and drive, but the car doesnt even budge. stall out as in i shift, rpms dont wven change after i let off the brake in drive or reverse. then eventually will stall out. i checked the detents, i can feel them all
Old Oct 20, 2023 | 01:39 PM
Probably not a trans problem. Did you leave the crank sensor in place when you r&r the trans? They tend to get busted when ya do that.....
