97 heats up on hills
Old Jul 2, 2019 | 11:55 PM
Rich164's Avatar
Rich164
Default 97 heats up on hills
Any advice appreciated guys. My 97 water pump was leaking and temp gauge would go from 200 up to about 215 on hill climbs. I figured easy fix but can't get it solved. Replaced water pump, fan clutch, thermostat and flushed system and burped after refill. Also topped off transmission fluid. Still heats up on hills. Thoughts? Did not replace hoses since not leaking. Thanks!
Old Jul 3, 2019 | 02:36 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You sure you got all the air out of the system?
Old Jul 3, 2019 | 07:03 AM
How's the radiator?
Old Jul 3, 2019 | 09:52 AM
Rich164's Avatar
Rich164
Radiator appears fine, no evidence of dirt, sediment or leaks. Thanks
Old Jul 3, 2019 | 05:02 PM
On the outside...... You can't see the inside, and that's what really matters. Get an infra-red temp gun, get the truck fully warmed up, and then check temps in different areas of the radiator, it should start pretty friggin' warm on the inlet side (drivers) and cool off as you move toward the passenger side. Check several places side to side, at at least three different levels. See what your temps look like.
Old Jul 3, 2019 | 06:13 PM
Rich164's Avatar
Rich164
I think I got all air out but plan to try again. Thanks
Old Jul 3, 2019 | 06:14 PM
Rich164's Avatar
Rich164
Good idea on the temp gun method
Old Jul 3, 2019 | 06:15 PM
It's more to make sure you are getting flow across the entire radiator.
Old Jul 3, 2019 | 07:19 PM
MoparFanatic21
I know some people here it was a real pain to get the air out
Old Jul 3, 2019 | 07:34 PM
Torxhead's Avatar
Torxhead
I would think it would be time for a flush out if it hasn't been done in the last 25k. Although a temporary mechanical gauge installation would confirm your reading.
