5.2 Running Hot-Leaking from Oil pan?!
99 ram 5.2 running hot due to coolant leak so it keeps running low. I put a gallon and a half in two days ago and it took another gallon and a half today. Behind the water pump and the wheep seal are dry, all around intake is dry. I’m having trouble seeing the back but when I follow the leak from the bottom up it has a rust trail leaking from the oil pan and from what I can, it’s coming from the oil pan. Oil level is low and I need a oil change, I’m not suspecting coolant in oil though. As of right now I’m pretty sure it only leaks while running
https://imgur.com/a/dbTH667
I've not pulled a Magnum 318 apart but the older ones had expansion plugs on the back of the heads and I think a couple on the block. The block mounted plugs will be between the engine and transmission. If they leak, the water will drain out the bottom. I've had luck with Barr's Leak stopping rear expansion plugs that are leaking a little. I'll bet if those are leaking, you've got some others about to let loose too. Especially if someone ran plain water for a bit. You CAN replace them in the truck but it would be easier to pull the engine and replace all of them. If you go that far, I'd replace the timing chain and oil pump with a high volume one before re-installation.
This is good news, I’ll go check it out now. Never heard of these in my life. First time for everything
I replaced it with the engine still in there, it’s tough but definitely do-able.
I checked behind the starter and also behind the motor mount, no luck. I looked on the other side and they’re dry also. I only can see two behind the head,
both are dry
both are dry
Trending Topics
Check around the bolts on the water pump. A couple of those go into the water jacket. They are supposed to have sealant on them. I'm thinking your water pump is about to pack it in though. If the seal is failing, it doesn't always come out the weep hole. If it only leaks under pressure while the engine is running, it is sprayed back on the block and will run down.
By the way, "freeze plug" is a misnomer. Yes, they pop out when the block freezes but only because the block cracks around them. They plug the oles where the sand is shaken out in the casting process. When I replace a worn out engine with a used one, I pop all of them out and flush the block with lots of water. You wouldn't believe how much rust and sand is in there until you get it out. I also replace the timing chain and oil pump. I put an engine with 98,000 miles in a truck once and it was still running strong 202,000 miles later when the truck broke in half from rot.
New or rebuilt? I've seen rebuilt parts last a week or forever. It depends on who rebuilt it and their quality control. I had to replace 6 alternators in a week as I kept getting bad ones. Two of those never left the store as I had them checked while I was still there. If there is a bolt on back cover, the seal may have gone bad.
