94 dodge ram motor swap 06 hemi 5.7
Old Jul 29, 2019 | 08:59 PM
Mikey69's Avatar
Mikey69
Default 94 dodge ram motor swap 06 hemi 5.7
Hey DF world,
I was wonder if its possible to swap the 5.7 hemi motor into my 94 ram? If possible what all is needed, I would like to keep my nv3500 5 speed in it. I have the entire 2006 dodge ram for parts.
Thanks for any info in advanced.
Old Jul 29, 2019 | 09:08 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Mikey69
Hey DF world,
NV3500 will bolt up but won't last 100 miles.
Here is what you need:
Pedal amenity with the box
Computer
Engine
02 Dakota Gauge Cluster
Driver side engine mount needs to be cut deeper about 1/2"
Custom Engine Harness using both your and the Hemi Computer
That's about it
Old Jul 29, 2019 | 09:24 PM
Mikey69's Avatar
Mikey69
Which trans would be best to swap with, with still being able to keep my dana 44, if i need to swap it to an automatic trans i can.
Old Jul 29, 2019 | 09:27 PM
Mikey69's Avatar
Mikey69
Computer
Engine
That's about it
Old Jul 29, 2019 | 09:30 PM
Nv4500
Old Jul 29, 2019 | 09:59 PM
Mikey69's Avatar
Mikey69
Nv4500
Am i able to use the same bell housing? Or does the entire trans need to be replaced? What about the transfer case will it still bolt up?
Old Jul 29, 2019 | 10:02 PM
Mikey69's Avatar
Mikey69
Computer
Engine
That's about it
Would i need to get a special adapter plate to mount the engine to the trans? Would i be able just to swap the core from the nv3500 to the nv4500 without swapping the bell housing? Also if i did swap the 35 to the 45 would my t case still mount up to it?
Old Jul 29, 2019 | 11:59 PM
MoparFanatic21
No same bolt pattern. What do mean by core? Also depends on the transfer case they came with different spline counts depending on the motor.
Old Jul 30, 2019 | 06:23 AM
Moparite's Avatar
Moparite
Someone makes the harness for this swap but it's like a grand.
Old Jul 30, 2019 | 06:27 AM
MoparFanatic21
Yes HotWire does. I originally am building my own. Really simple piggyback setup nothing to over difficult. Taking CCD to PCI or CAN BUS
