Exhaust leak p0308
Old Aug 13, 2019 | 09:05 AM
jimmyjames12's Avatar
jimmyjames12
Default Exhaust leak p0308
Do you guys know if a leak at the exhaust manifold can trigger a p0308 misfire at cylinder 8. Reason I'm asking is because an exhaust manifold bolt broke off flush on cylinder 8.
2001 ram 2500 5.9l
Old Aug 13, 2019 | 09:48 AM
Maybe...... but, there are a lot of other, more common causes for that as well.
Old Aug 15, 2019 | 08:30 PM
jimmyjames12
The p0308 came on after driving the truck 25 or so miles. 3 times already, but the truck drives and idles just fine.
Is the plenum a better candidate?
Old Aug 15, 2019 | 10:24 PM
HIghly likely. That, or a cat that is plugging up.
Old Aug 16, 2019 | 12:53 AM
jimmyjames12
I removed the o2 sensor(to test the cat) then drove 5 or so miles, but it was running badly so I just stopped and ordered the plenum repair kit.
I was able to successfully fix my transmission that was making a knocking sound, but all I did was replace gaskets and O-rings as all the internals looked good to this day I don't what fixed it, but I am scared to rev it hard now.
