Remove and replace AC Compressor 99 1500
Old Aug 15, 2019 | 07:17 PM
Originally Posted by 99CubbyBlue1500
Tech sheet says 32oz of freon and 8oz of PAG100. Does 8oz seem like a lot to y'all?
Not really. It distributes itself thoughout the system and is carried by the refrigerant. Just make sure you tell the folks that do the recharge you put it in.
Old Aug 15, 2019 | 08:14 PM
ol' grouch's Avatar
ol' grouch
Usually, when you replace the compressor, it will tell you how much and what PAG to use. A couple I've done recently said the oil was already in the compressor. If you're opening the system, you ought to replace the receiver/dryer too as it can only absorb about a table spoon of moisture.
I don't use the recharge kits but rather a manifold gauge set so I can see the pressures. Pump it down and let it sit for a half hour to see if it holds vacuum. If it does, start using cans but the first one should have dye in it so if there's a leak later, you can see it.
Old Aug 16, 2019 | 06:37 AM
Moparite's Avatar
Moparite
You have the compressor oil (oil that lubricates the mechanical parts inside the compressor) and then the oil that gets mixed with the freon. Tell the guy that will charge the system for you what you replaced and he will fill it accordingly.
Old Aug 16, 2019 | 11:26 AM
99CubbyBlue1500's Avatar
99CubbyBlue1500
What is this electrical connector? I seemed to have snapped it at the base of the connector, at the top of the hex head. Gonna have to replace it. Passenger side, front corner of the plenum cover.
Old Aug 16, 2019 | 12:00 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Coolant temp sensor
Old Aug 16, 2019 | 12:01 PM
99CubbyBlue1500
Coolant temp sensor
Figured as much. Wanted expert knowledge.
