No lights need help
Old Aug 26, 2019 | 06:09 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by Bromark56
no turn signal lights both exterior and on dash but does click...only brake light that works is the 3rd on the cab
Head over to the bone yard and get a different smart switch. That's one thing that is common and the third brake light bypasses it. If the lights start working, get a new multiswitch and it should be good.
Old Aug 26, 2019 | 06:19 PM
Bromark56's Avatar
Bromark56
where is the smart switch locatedand where is the multiswitch located im not the most savy on dodges its my first one
Old Aug 26, 2019 | 06:20 PM
Not sure what he means by smart switch, maybe the brake switch? Mutli-switch is likely the multifunction switch, turn signal/beam select/etc.
Old Aug 26, 2019 | 08:40 PM
Bromark56's Avatar
Bromark56
Took out the headlight switch and it was in **** poor condition. Hopefully this works
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I think he means headlight switch lol
Old Aug 26, 2019 | 08:49 PM
ol' grouch's Avatar
ol' grouch
Some places list it as a multi switch and some as a smart switch.The headlight switch is separate. It goes through the turn signal switch though for all the tail and clearance lights as well as the high low headlights.
Unlike older trucks, you don't have to pull the steering wheel. Just the upper and lower column covers. Pull the air bag fuse first though, or unhook the battery. There's just something about an explosive air bag next to my head when I work on a steering column that unnerves me.
Old Aug 26, 2019 | 10:23 PM
Yeah, the trick is to disconnect the battery, and wait at LEAST 10 minutes before playing with anything in the steering column. Air Bags can kill, and they have.
Old Aug 26, 2019 | 10:27 PM
Bromark56's Avatar
Bromark56
Default It worked!!!
After all it ended up being the headlight switch....all the lights are on ,but now one other thing the rear blinkers both right and left work when i hit the switch but the front passenger one doesnt blink but can here the clicker and the driver blinker only blinks if i press down hard on the blinker switch....My guess is i need a new blinker switch!? Am I wrong?
Old Aug 26, 2019 | 11:12 PM
MoparFanatic21
Sounds like it to me
Old Aug 27, 2019 | 09:04 AM
ol' grouch's Avatar
ol' grouch
The first time I worked on an air bag equipped car I was trying to track down an electrical problem. I was wailing away on what I thought was the radio amplifier. I finally knocked it loose with a hammer and turned it over and it said "air bag sensor, handle gently". I gently set it down and went up front and unhooked the battery.
