No lights need help
Old Aug 25, 2019 | 11:45 PM
Bromark56's Avatar
Bromark56
Default No lights need help
None of my lights work and i have replaced all the fuses all the bulbs have a new battery cleaned the ground on the core support cleaned the ground on the block and and am now stuck. The only exterior light that works is the brake light on the cab please help!!! This is on a 1997 dodge ram 2500 5.9L
Old Aug 26, 2019 | 09:15 AM
Have you had a look at your headlight switch?
Old Aug 26, 2019 | 09:20 AM
Bromark56's Avatar
Bromark56
i did and it looks fine i guess it coule be burnt out somewhere i cant see. does that switch conplete the circut??
Old Aug 26, 2019 | 09:27 AM
Yes, it does. If you don't have one yet, download the factory service manual for your truck from here. Wiring diagrams are in section 8W.
Old Aug 26, 2019 | 09:33 AM
Bromark56's Avatar
Bromark56
Okay thank you for your help!
Old Aug 26, 2019 | 09:34 AM
Since NONE of them are working...... look for the commonalities in the systems, should be easy to find with a bit of study.
Old Aug 26, 2019 | 01:52 PM
ol' grouch's Avatar
ol' grouch
Brake lights working? Turn signals?
Old Aug 26, 2019 | 01:54 PM
Bromark56's Avatar
Bromark56
no turn signal lights both exterior and on dash but does click...only brake light that works is the 3rd on the cab
Old Aug 26, 2019 | 05:37 PM
Got a trailer harness on your truck? Have a look where the trailer harness hits the main rear harness. Known to be problematic.
Old Aug 26, 2019 | 05:42 PM
Bromark56's Avatar
Bromark56
no brake lights no turn signals.......and yes i do habe a trailer harness ill give that a look!
