Horn fuse blowing...help with source of problem?
Old Aug 28, 2019 | 04:19 PM
tobnpr's Avatar
tobnpr
Default Horn fuse blowing...help with source of problem?
2000 Ram 2500, blown horn fuse (has dual hi/lo horns).
Replaced horns (tested), fuse still blows.
Swapped relay, no help there.
There's a brief noise from the horns before the fuse blows, so I know there's continuity.
All that's left (that I can think of) is the horn switch...could this be the culprit, somehow grounding out and blowing the fuse?
Any other ideas?
Appreciate any help. Nearly got creamed by some jerk changing lanes without looking, gotta get this fixed...
Old Aug 28, 2019 | 04:24 PM
Dean2's Avatar
Dean2
Any other ideas?
Yup. Just about 100% it is the switch or clock spring.
Old Aug 28, 2019 | 05:13 PM
tobnpr's Avatar
tobnpr
Thanks.
Such is my luck...
Another fun project
Old Aug 28, 2019 | 05:45 PM
HeikIlm's Avatar
HeikIlm
Problem is between the horn and the relay. Switch grounds the relay pin 85, and fuse goes to pin 86 and 30, so there's no way that switch is the reason for fuse to blow.
Old Aug 28, 2019 | 06:15 PM
Think I would be checking out the harness going to the horns, and see if it hasn't rubbed thru somewhere.
Old Aug 28, 2019 | 06:47 PM
tobnpr's Avatar
tobnpr
10-4...thought the same. I just love troubleshooting electrical problems....
Old Aug 28, 2019 | 07:14 PM
You and me both.... One of my LEAST favorite passtimes..... That's probably why I got stuck with 'em all the time.....
Old Aug 28, 2019 | 08:33 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I honestly love them. They are simple and fun
Old Aug 29, 2019 | 06:08 AM
Moparite's Avatar
Moparite
Stock horns? Have you tried just hooking up one? If you can get an amp probe you can see how much each horn is pulling.
Old Aug 29, 2019 | 10:24 AM
We apparently don't work on the same types of electrical problems.
