I am working on a 1992 Dodge B-250. I need instructions for removing steering wheel and gear box slop removal. I have tightened the adjustment clock wise, yet still hold to much free play in thew steering remanufactured steering gear box. I need help, Thanks
If it's a reman box, swap it out under warranty. Most them are a crapshoot. More often than not, you end up with a box worse than the one you are replacing.
