Issues when it rains
Old Aug 30, 2019 | 06:38 PM
What year do you have and how much lift are you running. A stock, late model truck run through 5 feet of water will have major problems down the road.
Lots of lift, and 44" tires, or maybe even larger by now....... 5.5 feet probably doesn't even come up to his hood.
Old Aug 30, 2019 | 08:23 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
01 Ram 5in lift 40" tires got 45"s but have to do some trimming. When I tried my makeshift snorkel (looked stupid imo made out of PVC) I had water over my hood
Old Aug 30, 2019 | 09:46 PM
John Carter's Avatar
John Carter
Well thanks yall guess got some work to do next weekend. Hopefully find the issue and resolve it. Thanks for all the input and advice again apologize for not being mechanically correct.
Old Aug 30, 2019 | 10:02 PM
MoparFanatic21
We all have to learn
Old Aug 31, 2019 | 09:26 AM
And that is what this site is all about.
Old Aug 31, 2019 | 10:10 AM
ol' grouch's Avatar
ol' grouch
One MAJOR warning about high water transits. Make sure the road is still under there. Back in the 80's when I was a rescue volunteer, we went looking for a guy who decided to drive through a couple of feet of water. The road had washed out and his truck dropped off the pavement. The truck was found as soon as the water went down and we could get in there. It took a week to find his remains in some brush.
Old Aug 31, 2019 | 11:36 AM
Moparite's Avatar
Moparite
Also water turns to steam when it hits hot exhaust, then travels upward where the ignition is. Had a problem with my power wagon where water would fall down from the hood/cowl and do just this. The fix was to spray some WD40 into the distributor cap.
Old Aug 31, 2019 | 03:03 PM
MoparFanatic21
I use die electric grease on EVERYTHING electrical, even inside the cab. I think that's why I never had an issue
Old Aug 31, 2019 | 11:10 PM
1974dodgeowner's Avatar
1974dodgeowner
crank position sensor getting wet maybe?
Old Oct 26, 2019 | 01:17 PM
John Carter
Default Found the issue
Sorry for the late reply been busy with work and with a wedding but I found the issue it's my ignition coil its cracked
