Need help with my 97 Dodge Ram 1500
Old Sep 11, 2019 | 01:05 PM
Donald Vallee's Avatar
Donald Vallee
Default Need help with my 97 Dodge Ram 1500
I just bought a water pump for 97 Dodge Ram 1500 bolted it up and now it’s leaking from the bottom of the pump what do I do
Old Sep 11, 2019 | 01:17 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Replace it. You can get a bad one out of the box
Old Sep 13, 2019 | 06:24 PM
2bit's Avatar
2bit
Once you're in that deep, throw a timing chain on it too.
Old Feb 24, 2020 | 04:09 PM
Donald Vallee
Default Cam and crankshaft timing
i know it’s been awhile I got the water pump thing fixed but now I had to replace the whole gear in the timing but it seem every time I line it up it’s 180 out and I’ve tried this five times now what do I do from this point
Old Feb 24, 2020 | 04:17 PM
2bit's Avatar
2bit
Some timing sets have 2 sets of dots on them. It's the smaller dots that are the timing mark. Take some pictures so we can have a look.
Old Feb 24, 2020 | 04:21 PM
Donald Vallee
Default Won’t let me add the picture
I took the picture and tried to add it but it won’t seem to add it but yes it does two smaller dots as on both gear that are in line with each other once I put it all back together I tried to start it and I got a back fire but it won’t start up like I have no compression everything just kinda spins and nothing happens
Old Feb 24, 2020 | 07:18 PM
I do believe that with the dots at 6 and 12, cylinder 6 is in firing position.
Old Feb 24, 2020 | 08:12 PM
Donald Vallee
Default Tried this
tried this and it worked I am in time but I still don’t have a truck that starts
Old Feb 24, 2020 | 09:34 PM
Did you move the distributor at all in your travels thru the engine compartment? Got spark? Fuel pressure? Injector pulse?
Old Feb 25, 2020 | 01:12 AM
Donald Vallee
Default Trying this next
I never did move the distributor or anything that had to do with it im checking here in like six hours when the suns up so that way I can figure out if I need a fuel filter or fuel pump or a new ignition coil and distributor cap or any of the components like that
