Timing gear replaced
Old Sep 15, 2019 | 09:05 PM
303hunter's Avatar
303hunter
Default Timing gear replaced
Had the timing chain replaced in my 1997 Ram 5.2 Friday. My mechanic called me at work to let me know that he’d never seen one stretched that bad.without breaking. Anyway, I owe you guys a ton of thanks for letting me know about the timing chain issue. My truck has a bunch more power, and is getting better gas mileage.
Old Sep 16, 2019 | 12:11 AM
2bit's Avatar
2bit
Glad to hear it's running better again.
Old Sep 16, 2019 | 07:09 PM
Yep, changing the timing set on my 96 was one of the best improvements I did on that truck. It was a major difference.
Old Sep 17, 2019 | 06:07 PM
Torxhead's Avatar
Torxhead
I have seen them loosen so bad as to skip teeth. Then ignition timing goes all to hell.
Old Sep 17, 2019 | 06:42 PM
ol' grouch's Avatar
ol' grouch
I'll bet you've noticed an increase in fuel mileage and come cold weather, you'll find the heat will run you out.
