No start dodge
Old Oct 20, 2019 | 09:11 AM
UncleMo's Avatar
UncleMo
Default No start dodge
I have a 1998 Dodge 1500 5.2l 5 speed. Truck wont start unless l boost it, I have changed the battery,I'm leaning toward the either the solenoid is shot or the whole starter is done. I have checked the starter relay fuse and it is fine. Am I leaning in the right direction or could it be something else?
Old Oct 20, 2019 | 09:40 AM
Dirtymaxx66's Avatar
Dirtymaxx66
Does it crank over slowly or just click before you jump it?
Old Oct 20, 2019 | 09:53 AM
Ramman18's Avatar
Ramman18
Battery is not holding enough charge. Question is why. Is it old or is it a wire or is it the alternator?
Old Oct 20, 2019 | 09:58 AM
UncleMo's Avatar
UncleMo
No, it just clicks
Old Oct 20, 2019 | 10:02 AM
Dirtymaxx66
Starter is most likely old and getting stuck. This is a extremely common symptom of a failing starter motor. Take it off and get it tested, if it fails a test get a new one(recommended) or attempt to clean and grease your old one
Old Oct 20, 2019 | 10:06 AM
Is it the relay clicking, or the starter?
Old Oct 20, 2019 | 10:13 AM
UncleMo's Avatar
UncleMo
Thanks, I kinda thought thats what the problem is. I'm going tomorrow to get another starter.
Old Oct 20, 2019 | 11:12 AM
nyrainman's Avatar
nyrainman
I had a similar problem on my 1995 Ram 2500 and it was where the wires connect to the starter. The connectors on the starter were bad, rusty and rotted. I replace the starter and that fixed the problem.
Old Oct 21, 2019 | 07:24 PM
2bit's Avatar
2bit
REMY 99612 {Click Info Button for Alternate/OEM Part Numbers} Remy Gold Info
$90.79$0.00$90.79
Check your cables first, but if it takes 2 batteries to spin the starter, it's shot.
