driving lights & headlights
Old Dec 3, 2019 | 10:11 AM
byteme's Avatar
byteme
im thinking due to the strokes ive had i completely over thought this and forgot how something this basic works , but brain reboot and were good ,I still havent figured out the headlights
Old Dec 3, 2019 | 10:13 AM
byteme's Avatar
byteme
4 light NON-sport? The 4 headlight systems only came on the sport package. Everything else has only two. Was your truck modified from factory stock?
sorry should have said two lamp i put sport light lenses in cause i got em cheap but its still a 2 lamp system but its a non sport as i said, sorry strokes do weird things to your mind ..awaiting your response
Old Dec 3, 2019 | 09:14 PM
Do you just have the two-filament bulbs in the outer housings then?
Do you have the service manual for your truck? (get one here, if you don't, wiring diagrams are in section 8W.)
Headlights switches were also problematic on these trucks, may not hurt to check that.
I don't remember if the switch on your truck provides ground path, or power, for the headlights......
Old Dec 3, 2019 | 10:29 PM
byteme's Avatar
byteme
Yes on the dual filiments high/low and yes i have a mnaual i grabed it here
Ill check out the switch its just weird one side died with the driving light or closly after each other
these trucks have the worst headlights ever
Old Dec 4, 2019 | 01:52 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can say that again
