PCV clicking constantly
Old Nov 20, 2019 | 01:40 PM
jaze5736's Avatar
jaze5736
Default PCV clicking constantly
I found that my PCV valve on the driver side of the engine (5.2v8) was constanly clicking and rattling so I figured it was bad. I replaced it and it continued to rattle so i replace the vacuum hose that goes from the side of the intake to the PCV since it was dry and cracked. I assumed that it was leaking vacuum and causing it to rattle but with a brand new hose and PCV is continues to rattle does anyone know anything about this.
Old Nov 20, 2019 | 03:01 PM
Ramman18's Avatar
Ramman18
I don't know for sure but since the pcv vents crankcase pressure from blowby would this mean you have extensive blowby / worn rings?
Old Nov 20, 2019 | 07:25 PM
true blue's Avatar
true blue
Get a mopar PCV if your not sure. Aftermarkets rattle, especially at idle. I put a mopar back into my beast n she's quiet all the time now.
Old Nov 21, 2019 | 12:22 AM
Ramman18's Avatar
Ramman18
Yes, be sure to have a Mopar PCV only. They may seem like a nothing part, but internally, the quality (or lack thereof) really shows.
Old Nov 21, 2019 | 08:04 AM
PCV rattle is normal. Its a valve. It tries to keep a constant vacuum on the crank case, and it does that by varying the amount of vacuum applied. Thus, it rattles. Some are definitely louder than others..... But yeah, get the mopar PCV, they are actually the correct flow rate.
Old Nov 25, 2019 | 10:22 AM
jaze5736's Avatar
jaze5736
does anyone know where I can get a Mopar PCV for the 5.2 v8?
Old Nov 25, 2019 | 10:23 AM
Ramman18's Avatar
Ramman18
Any dealership.
Old Nov 25, 2019 | 02:58 PM
true blue's Avatar
true blue
Amazon
Old Nov 26, 2019 | 07:45 AM
PCV for my truck was like 8 bucks at the dealer, and they had it on the shelf.
