Colant leak at firewall 99 dodge ram
Old Nov 24, 2019 | 08:40 PM
judgeholden's Avatar
judgeholden
Tech at shop saw leak and moved me up to Monday. Lime green fluid is coolant. Fluid seems to be behind firewall insulation and running down. I will update when tech calls me tommorow.
Old Nov 24, 2019 | 10:22 PM
2bit's Avatar
2bit
Your A/C runs when you have heat in any position that includes defrost. The A/C dries the air so the defrost works better. Lime green is also the color of the oil in some A/C systems. Stick your finger in it. Is it antifreeze or oil?
Old Nov 24, 2019 | 10:34 PM
judgeholden
antifreeze.
Old Nov 25, 2019 | 11:14 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by judgeholden
antifreeze.
Well lying must have a special truck because there is no coolant passages behind the AC drier
Old Nov 25, 2019 | 02:36 PM
Torxhead's Avatar
Torxhead
Just guessing here but what about a leaking softplug or head gasket ?
Old Nov 25, 2019 | 03:45 PM
judgeholden
Tech gave me the bad news. Freeze plug in back side of head. Needs to remove head, so into it for 2600. Ugh. 1500 labor and 800 parts + tax i guess. Is that fair cost? Not sure if I want to spend much more on this truck but cant repair it by myself due to location of leak. Thanks.
Old Nov 25, 2019 | 03:59 PM
MoparFanatic21
Tech gave me the bad news. Froze plug in back side of head. Needs to remove head, so into it for 2600. Ugh.
Now that makes sense! Sorry to hear that
Old Nov 25, 2019 | 07:45 PM
ol' grouch's Avatar
ol' grouch
Personally, I'd pull the engine and replace all the expansion plugs. I've never replaced just one. One may be leaking but another one, or two or...might be getting soft. I usually take the opportunity to flush the block. However, I do my own work and usually have several cars to drive too.
Old Nov 26, 2019 | 07:31 AM
800 bucks for parts? What all is he replacing????
Old Nov 26, 2019 | 08:09 AM
judgeholden
head gasket set 438
head bolt set 411
labor 1522
disposal 40
tax 234
