Transmission.... again.
Old Jan 13, 2020 | 09:47 AM
HeikIlm's Avatar
HeikIlm
Originally Posted by Sheldon Fuller
Ok, so I dropped the pan and saw a broke shim or something that sits on top of a spring, below an arm. I’m not exactly what it is or does, maybe an issue? Anyone know what the shin circled is? Maybe easy fix?
Do you have a picture of the broken part? That circled part is rear band lever and piston.
Old Jan 13, 2020 | 10:06 AM
Sheldon Fuller's Avatar
Sheldon Fuller
sorry I’m in school at the moment, but I zoomed in and tried to demonstrate somewhat what it looked like.
Old Jan 13, 2020 | 05:53 PM
Sheldon Fuller
On, off, on, off, on..... watch the odometer. Don't start the truck. Just cycle the key three times, and leave it on. It may not do anything at all. I just don't remember.
hey you, any input on this?
Old Jan 13, 2020 | 06:20 PM
Moparite's Avatar
Moparite
That's the key dance, Depending on the year of your truck you can get codes that way.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Jan 13, 2020 | 06:22 PM
Sheldon Fuller
there were no codes
Old Jan 13, 2020 | 06:25 PM
Moparite's Avatar
Moparite
What year truck? This is for the newer ones...
Old Jan 13, 2020 | 06:26 PM
I'm not even sure there is supposed to be a shim there..... Wonder if that was someone elses answer to a worn band, that wouldn't adjust properly.
Old Jan 13, 2020 | 06:39 PM
Sheldon Fuller
well you see I’m not sure if it’s a shim or honestly what it is, it just looks like a little spaced to make full coverage on the spring.
Old Jan 13, 2020 | 07:16 PM
There should only be one large spring in there.... Is there a second, smaller one as well??
Old Jan 13, 2020 | 07:43 PM
Sheldon Fuller
one spring, I’m fixing to just rebuild it. Any idea on some good links, on how to rebuild it.
