Transmission.... again.
Old Jan 14, 2020 | 06:10 PM
  #31
Sheldon Fuller's Avatar
Sheldon Fuller
How much is that one? You could do a level 2 viper trans for around 800, with torque converter...... (and that would be a STOUT trans when you were done.....)
ehh around $300, I just don’t have a lot of money to do a full build
Old Jan 14, 2020 | 06:25 PM
  #32
Maybe this one? (and I would seriously consider the bushing kit for 22 bucks as well.) Still would need a torque converter, but, at least this one comes with both bands....... (apparently.)
Maybe talk to one of your local transmissions shops, and see what THEY use.......
Old Jan 14, 2020 | 11:08 PM
  #33
Sheldon Fuller
what do the extra bushings do?
Old Jan 15, 2020 | 08:39 AM
  #34
Replace the possibly worn bushings in the trans. (likely need to press them out/in....) Bearing/seal driver would likely work.
Old Jan 15, 2020 | 12:43 PM
  #35
Sheldon Fuller
ok, and this is a good kit for a completely watered out trans? Like I said it was submerged under water and clutches slipped, this kit will fix it?
Old Jan 15, 2020 | 06:53 PM
  #36
I have no experience with it..... So, I don't know about quality. But, it *should* work. Just make sure that everything is CLEAN and DRY when you put it back together.
Old Jan 15, 2020 | 07:00 PM
  #37
Sheldon Fuller
would this do the OD unit clutches to or just the trans?
Old Jan 15, 2020 | 07:01 PM
  #38
I do believe it does both.
Old Jan 15, 2020 | 09:40 PM
  #39
Sheldon Fuller
alright I’ll let you know how she goes I’ll post more if I need help
Old Feb 11, 2020 | 08:34 PM
  #40
Sheldon Fuller
Ok so the transmissions rebuilt and in it moves! But, now it doesn’t want to downshift on its own, any ideas?
