I am currently restoring my 1996 Dodge RAM 2500 Club Cab interior, and was wondering if I have to remove the bench seat in order to do so? Because if so, I’m out of luck because for some reason, the bench seat refuses to “lift up” as if it’s stuck I pull on the levers, and nothing. Is there any way to unstick it? Secondly, my seatbelt is twisted from the retractor (behind the “B” pillar) making retraction difficult. How does the B pillar remove? (Passenger side) I’ve unscrewed the screws, but it’s like it’s glued! (It’s not) I’ve attached a picture of the “B” pillar for reference;
thank you!
thank you!
Rear seat has latches that the lever is supposed to release. You can try pushing DOWN on the seat, pulling the lever, and lifting up. If that doesn't work, you are likely going to have to contort yourself around, peak under the seat, and see if you can release them manually.
I haven’t tried pushing down, but how could I unlatch them manually?
Pry that plastic cover over the hinge outwards, you should be able to see the latch lever. Bend a hook from, I don't know, coat hanger maybe, and pull the lever forward. I took couple of pictures, not the best but you'll see how they work. Be carefull with them plastic covers so you don't break them.
Took couple of pictures more from drivers side. Manage to break the plastic cover mounting as can be seen in lower left corner. Also realized that drivers side latch or hinge is bent because it doesn't go under the notch. But the way the latch is built, HeyYou is correct that pushing down should help, if all the cables are intact:
Oh yeah, and the twisted seat belt. If I understood correctly your problem, you don't need to take anything off. Just pull the twisted section through the upper guide that's bolted to the b-pilar.
