Getting obd 22 code - Engine coolant temp sensor out of range
Old Jan 24, 2020 | 12:29 PM
  #21
rrb6699's Avatar
rrb6699
Disconnect battery cable. Turn on headlights. Turn off headlights. Reconnect battery cable. Turn ignition to "On". (not start) Count to 10. Start engine, and let the idle settle down. Drive it. See what happens.
tried this today.
starts cold ok. so I drove 2 miles out and back.
then turned it off as if I was going into a store.
when I restarted it, check engine lite still illuminated. drove it 5mi. returned shut off for about 4mins. tried restart
same deal. fires but stalls. hissing noise heard, try to crank 3 more times before it starts but total amount of time to crank it is about 15 seconds which gives me a "Gen" light.
temp gauge works. reads under 200°.
Old Jan 24, 2020 | 06:26 PM
  #22
Temp gauge uses a different sensor than the PCM on your truck. (96, right?) So the gauge in the dash may be right, but, need to know what the PCM thinks is going on. Only way to do that is with a scanner. I would be tempted to drive it to the parts store, shut it off, hook up the scanner, and see if you can read coolant temp via the scanner. See what it says.
Old Jan 24, 2020 | 10:21 PM
  #23
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
They can see data but getting them to show you is another thing as they say it's a liability (stupid I know)
Old Jan 25, 2020 | 08:04 AM
  #24
Moparite's Avatar
Moparite
If you have a Android or Windows device( i think others are available also) get one of these...
Amazon Amazon
Old Jan 25, 2020 | 10:42 AM
  #25
MoparFanatic21
https://www.amazon.com/BAFX-Products...iglink21627-20
Make sure it connects via credit Bluetooth not WiFi
Old Jan 26, 2020 | 11:20 AM
  #26
rrb6699's Avatar
rrb6699
my truck mfg date was a few months before they put obd-II
I don't have digital speedometer and have to read codes with check engine light by counting the flashes.
I just cleaned the sensor/idle air control circled in red on previous posts here. o-ring looked fine so put it back in. gonna try that today. still need a dipstick tube bolt.
