loud noise at high rpms
Old Jan 21, 2020 | 01:41 PM
Parker Houston's Avatar
Parker Houston
Default loud noise at high rpms
during acceleration at about 2500 rpms my truck will start making a loud noise, I believe it is the fan but I don't know for sure. Can anyone help me out?
Old Jan 21, 2020 | 02:43 PM
See if the fan is hitting the shroud. If it is, it should be pretty obvious.
Old Jan 22, 2020 | 09:26 AM
Parker Houston
Alright thank you!
Old Jan 22, 2020 | 09:43 AM
Open the hood and operate the throttle by hand or have someone sit in the truck and pres the gas. See if you can isolate where it's coming from.
Old Jan 22, 2020 | 01:30 PM
Parker Houston
thanks!
Old Jan 22, 2020 | 02:31 PM
Torxhead's Avatar
Torxhead
If the fan hits the shroud on the bottom, that would indicate a sagging motor mount. If not a worn fan belt could be the issue. A bad fan will cause the motor to run hotter.
Old Jan 30, 2020 | 09:20 PM
Parker Houston
The fan is not hitting the shroud, I replace the belt and for a few days it didn’t do anything but then it quit making the noise for a few hours today but it’s back
Old Jan 30, 2020 | 10:27 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Remove the belt rev it high and see if it still makes the noise
Old Feb 1, 2020 | 06:18 PM
2bit's Avatar
2bit
What does the noise sound like? Ticking? Squealing? Whining?
Old Feb 2, 2020 | 09:58 AM
Moparite's Avatar
Moparite
X2! How about posting a video of the sound? Link it here from you tube.
