Electrical nightmare
Old Jan 22, 2020 | 10:58 PM
DBowen's Avatar
DBowen
The fuel pump is a Delphi
Old Jan 22, 2020 | 11:02 PM
DBowen's Avatar
DBowen
Should clarify ‘nothing’ the engine cranks but does not start
Old Jan 23, 2020 | 07:48 AM
Delphi is a good brand. (usually....)
Need to find out what's missing. Your engine needs three things, fuel, spark, and air. (ok, and compression..... four things.) If one of them is missing, it won't run. I don't think air is the issue...... so, fuel or spark.
Old Jan 23, 2020 | 10:47 AM
DBowen's Avatar
DBowen
Would it start when priming without spark ?
Old Jan 23, 2020 | 12:14 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Won't start without spark.
Old Jan 23, 2020 | 02:34 PM
DBowen's Avatar
DBowen
Then something other than fuel pump and relay is restricting or not allowing the fuel to flow ?!
Old Jan 23, 2020 | 04:20 PM
Do you have spark? Do you have good fuel pressure?
Old Jan 23, 2020 | 10:30 PM
DBowen's Avatar
DBowen
Yes on both - spark and fuel pressure - what if an injector is shorted will it cause all injectors to stop firing ?
Old Jan 24, 2020 | 07:07 AM
Nope, you would just have one dead cylinder, and it would set a code. Next check is see if you are getting injector pulse. Test lite, or noid light will tell the tale.
Old Jan 24, 2020 | 12:31 PM
DBowen's Avatar
DBowen
Ok that will be my next step then - will post when I know - thank you
