Electrical nightmare
Old Jan 24, 2020 | 03:32 PM
  #21
DBowen's Avatar
DBowen
Went out and checked for any kind of pulse at the injectors - nothing
Old Jan 24, 2020 | 03:58 PM
  #22
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Then the engine isn't getting fuel. You have a wiring issue (can check that with a cheap multimeter), cam sensor, or PCM
Old Jan 24, 2020 | 04:19 PM
  #23
DBowen's Avatar
DBowen
Next step !
Old Feb 4, 2020 | 08:02 PM
  #24
DBowen's Avatar
DBowen
Changed out the crank position sensor today - didn’t solve the problem though - should I be getting voltage to the sensor plug with the key on ? I am not
Old Feb 4, 2020 | 08:05 PM
  #25
MoparFanatic21
I am unsure of that would have to look at the diagrams
Old Feb 4, 2020 | 09:13 PM
  #26
Yes, Should see five or eight volts on one of the wires.
Old Feb 4, 2020 | 09:16 PM
  #27
DBowen's Avatar
DBowen
Default Nothing .... the other sensors around the manifold are putting out voltage bu
Nothing .... the other sensors around the manifold are putting out voltage but neither the crank position sensor or injectors are
Old Feb 5, 2020 | 05:17 PM
  #28
Check the wiring to the crank sensor. Most of those sensors draw power from the same place....
Injectors only see power for about 3 seconds at initial key on, after that, only if the PCM sees the engine turning. (via the crank sensor...... )
Old Feb 5, 2020 | 08:28 PM
  #29
DBowen's Avatar
DBowen
Ok - thank you for direction on next step !! Will repost when done
