fuel pressure regulator location.
Old Jan 25, 2020 | 06:05 PM
mrt2you's Avatar
mrt2you
Default fuel pressure regulator location.
i have a 2000 ram 1500 4X4 w 5.9l auto. 90K miles.
i just got a fuel pressure regulator trouble code today.
after a quick google search it says it's located on the fuel pump.....CORRECT?
the truck has always been a hard cold start since i bought it a few months ago. my original plan was to replace the pump in spring. if the FPR is located on the pump i might as well replace the pump now when dropping the tank for the regulator. or is a new regulator included with a pump?
Old Jan 25, 2020 | 08:47 PM
Erm, what code did you get? I didn't think the older trucks PCM even cared about fuel pressure.....
Old Jan 28, 2020 | 06:43 AM
mrt2you's Avatar
mrt2you
i didn't scan it myself.
if i remember correctly, the person scanning said there was a open circuit to the fuel pressure regulator.
Old Jan 28, 2020 | 06:51 AM
HeikIlm's Avatar
HeikIlm
Pressure regulator has nothing electric, therefore there can't be an open circuit.
