Ignition replacement?
Old Jan 26, 2020 | 07:21 PM
Liddlez's Avatar
Liddlez
Default Ignition replacement?
Hi all, long story short, my ‘96 2500 was stolen a couple years back, the thieves popped, and replaced the ignition, and one door lock. Is there any way to revert/recode the ignition, and door lock to factory standards? In other words, can someone re-create the original switch, and lock from either the key, or original door lock? Thank you.
Old Jan 26, 2020 | 08:04 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Would have to remove both to get them re-keyed. A good locksmith good pick the ignition for you
Old Jan 26, 2020 | 08:16 PM
Liddlez's Avatar
Liddlez
“Rekeyed” as in new key, or current key?
Old Jan 26, 2020 | 08:53 PM
You bring them the key you want to work, and the two lock cylinders, and any decent locksmith can make it happen. Probably not too hideously expensive either.
Old Jan 26, 2020 | 09:15 PM
Liddlez's Avatar
Liddlez
Gotcha, thank you. I called, and they said they could. Fairly cheap. $300 for ignition, and lock. It gets annoying to unlock manually. The truck does have power locks, but they don’t work. I just hear a “whirring” noise when I toggle the switch.
Old Jan 26, 2020 | 09:53 PM
MoparFanatic21
That's high I paid $30 for my two door locks. Sounds like the actuator is bad
Old Jan 27, 2020 | 06:45 AM
Moparite's Avatar
Moparite
The ignition lock cylinder you need to get from the dealer if you want it to match your original key. There is no way to take apart and put back together the cylinder the way it's made. A better option is to get a cylinder from a later truck(98) i believe they made the cylinder different so you can do it. The door cylinder i'm not sure about.
Old Jan 27, 2020 | 06:50 AM
MoparFanatic21
96 and door locks can be done had them done on my 96 and 01. Hate having different keys
