Where does this top of engine bracket attach
Old Feb 8, 2020 | 06:15 PM
aggiejet's Avatar
aggiejet
Default Where does this top of engine bracket attach
The black bracket that is connected to the alternator and has a black grounding wire attached to it which runs to alternator is the one in question.
I obviously have it incorrectly installed and it’s blocking the thermostat housing enough I can’t attach the radiator hose.
Old Feb 8, 2020 | 06:46 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It attaches where that bolt is on the intake (left of the bracket in the pic)
Old Feb 8, 2020 | 07:10 PM
aggiejet's Avatar
aggiejet
That’s a fuel rail mounting bracket bolt.
Old Feb 8, 2020 | 07:21 PM
aggiejet's Avatar
aggiejet
Default Had bracket upside down
Finally remembered the air filter housing needed a stud to mount to. Which is part of this bracket. I was trying to put it in upside down. Scheesh!
Old Feb 8, 2020 | 07:25 PM
Ramman18's Avatar
Ramman18
You have the right hole but the bracket is upside down! Flip it over and everything will fit!
Old Feb 8, 2020 | 07:26 PM
Ramman18's Avatar
Ramman18
Wow, I literally missed you by seconds.
Old Feb 8, 2020 | 08:43 PM
MoparFanatic21
I clearly wasn't paying attention
Old Feb 8, 2020 | 09:38 PM
aggiejet's Avatar
aggiejet
No problem. Thanks for responding. I was just completely vapor locked.
