98 ram 1500 sport gear ratio help
Old Feb 10, 2020 | 07:53 AM
Moparornocar440's Avatar
Moparornocar440
Default 98 ram 1500 sport gear ratio help
I have a 98 Dodge Ram 1500 9.25 rear end running 35in tires. The gear ratio is bad it goes about 50 mph in 2nd gear running 2200 rpm. It is 4x4 with the Dana 44 and I was thing 3.90 gears. Does anyone know what would be a good ratio for 35 in y’all tires. Plus it’s so sluggish and uses a ton a fuel getting it going. Granted I know the 360 is a Thirsty motor
Old Feb 10, 2020 | 08:20 AM
Probably 3.55 gears stock. If you are going to go to the trouble of re-gearing, 4.10s at a minimum, 4.56 would be better.
Old Feb 10, 2020 | 08:51 AM
2bit's Avatar
2bit
I agree with Hey You
Old Feb 12, 2020 | 12:45 AM
zildjian3707's Avatar
zildjian3707
yea i went to 4:56 with my 35's. im speedy Gonzales now
Old Feb 12, 2020 | 10:54 AM
00t444e's Avatar
00t444e
4.56 or even 4.88 if you can find them for the Chrysler 9.25.
Old Feb 12, 2020 | 11:22 AM
Moparornocar440
ok appreciate it. I’ll give it a shot see what I can find
Old Feb 12, 2020 | 02:24 PM
And please remember, if you change the rear gears, gotta change the front gears as well. Mismatched ratios will make ugly sounds, right until something breaks.
Old Feb 12, 2020 | 03:00 PM
00t444e's Avatar
00t444e
I ordered from Ron's machining Service when I regeared my Jeep, great prices and good customer service.
http://www.ronsmachiningservice.net/...-usa-gear-pkg/
