1998 Dodge Ram 1500 Loud Whistle at 3k+ RPM
Old Feb 12, 2020 | 12:10 PM
NickB77's Avatar
NickB77
Default 1998 Dodge Ram 1500 Loud Whistle at 3k+ RPM
My first post!
1998 Dodge Ram 1500 5.9l v8 4x4 Laramie
Okay so a while back I replaced my PCV valve and hose on my truck. After I had replaced it I noticed this weird whistle when I step on it. It’s been months now and after replacing the grommet the pcv valve goes into, checking for vacuum leaks, checking for exhaust leaks(flow master super 10 supposedly has some sort of exhaust baffle issue that sounds similar), I still cannot figure it out. Is it the PCV valve?
Old Feb 12, 2020 | 12:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by NickB77
My first post!
If the PCV valve wasn't a Mopar, that could be the issue.
Old Feb 17, 2020 | 11:19 AM
NickB77's Avatar
NickB77
Replaced the PCV valve with a mopar PCV valve and it’s still there
Old Feb 17, 2020 | 11:47 AM
Gasket between the air box, and throttle body?
Old Feb 17, 2020 | 03:29 PM
MoparFanatic21
What HeyYou said or the throttle body gasket
