Valvetrain noise
Old Feb 23, 2020 | 09:46 PM
Sledder10's Avatar
Sledder10
Default Valvetrain noise
Last summer I found a 5.9 out of a wrecked truck. Pulled it apart, installed a mild RV/towing cam, fixed the plenum (I hope) and put in my truck in place of the 318.
Ever since its been installed, it has a lot of valvetrain noise on startup until it builds oil pressure. Unfortunately, I didn't hear it run beforehand, so I have no idea if the cam and/or install caused it. Once it builds pressure it runs pretty smooth, but still some intermittent ticking.
I got a mild cam with the goal of not needing the change anything else besides the tune. Springs are factory. I did have to buy new lifters as the factory ones were pitted pretty bad. It was my first cam install, so let's not assume I did everything right.
1st question is, is the noise anything to be worried about since it's mainly during startup. 2nd, if it's something I need to look at, where is the best place to start? I am currently using crap oil, I intend to change with a decent synthetic but I doubt it will make much of a difference.
Thoughts?
Old Feb 23, 2020 | 10:19 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thoughts?
Any noise is a concern. Try to pinpoint where it is coming from. So you have headers on it?
Old Feb 23, 2020 | 10:22 PM
Sledder10's Avatar
Sledder10
Well it's through the whole valvetrain during startup best I can tell. No Headers, factory manifolds.
Old Feb 23, 2020 | 10:28 PM
Sledder10's Avatar
Sledder10
I also put a new factory replacement oil pump in during the swap while I was in there.
Old Feb 23, 2020 | 10:30 PM
MoparFanatic21
Headers? Could be lose exhaust bolt. Headers are known for that. Pump could be defective. Should have went with a high volume pump
Old Feb 23, 2020 | 10:33 PM
Sledder10's Avatar
Sledder10
I did some reading on the pump. I didn't gather that a high volume pump benefited my mostly stock motor at all. My conclusion could be wrong, but even so I shouldn't "need" it, right?
Old Feb 23, 2020 | 10:36 PM
Sledder10's Avatar
Sledder10
I'll go through and check manifold bolts.
Old Feb 23, 2020 | 10:55 PM
MoparFanatic21
Don't need it no, but it does help with oil pressure in an older engine
Old Feb 24, 2020 | 08:27 AM
What lifters did you install?
Old Feb 24, 2020 | 09:03 AM
Sledder10's Avatar
Sledder10
Mopar Performance Hydraulic Roller Lifters P5249862
