Hacking/flashing 99 ram 1500 pcm 5.9v8
Old Feb 25, 2020 | 03:35 PM
daveyg's Avatar
daveyg
Default Hacking/flashing 99 ram 1500 pcm 5.9v8
Tried searching with 5 different terms but coming up short of what I’m looking for. Is there a way to connect a pc (laptop) to the factory 5.9 pcm (ecu) and read the existing fuel and ignition map and possibly edit it? I have an idea for a very minor power adder I want to put on my current 5.9 (which has 122k) but I want to be sure I can cheaply and easily edit the fuel and ignition maps (just a smidge) before I start fabricating parts. I’ve got a fair bit of experience with making things, including small microprocessor controlled robots, and I’ve read that the dealership had the ability to re-flash the pcm just using the CAN interface (often referred to as the OBD-2 plug) and that’s what I’m trying to figure out how to hack via. Has anyone done this successfully on a 2nd gen Ram or am I going to need to just send my pcm to someone like Hughes to have them reprogram it to my desired spec, or worse, switch to a full standalone system?
Old Feb 25, 2020 | 03:38 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Your truck doesn't use the CAN BUS system it uses PCI. Yes you can program from a laptop but you need the software to do it and an OBDll plug to USB plug.
Old Feb 25, 2020 | 04:12 PM
daveyg's Avatar
daveyg
Do you happen to know a good software example that can do that? I know of romraider and tunerpro, which are two free software flashing versions that a lot of the jap car guys locally use.
Old Feb 25, 2020 | 05:59 PM
MoparFanatic21
I do not. I know how the systems operate. Never tuned a car because I don't know enough. I just upgrade the engines. That's why I'm swapping a Hemi in my Ram instead of the 360
Old Feb 25, 2020 | 07:30 PM
HP Tuners (they advertise on this site.) has the software you need, along with the hardware to go with it. (you need to supply your own laptop.) I think its in the neighborhood of 5-600 bucks for a single vehicle license though. It just ain't cheap. I have not found any freeware that will do the job.
Old Feb 25, 2020 | 09:45 PM
daveyg's Avatar
daveyg
What freeware have you tried if you don’t mind my asking?
Old Feb 26, 2020 | 07:47 AM
None. Because it doesn't exist. You can find it for older GM cars, but, nothin' for Dodge.
