2000 1500 5.2 No start
Old Mar 29, 2020 | 09:17 PM
Kay_tar's Avatar
Kay_tar
Default 2000 1500 5.2 No start
Ok, truck is a 2WD, 5.2 Extented cab 2000 year Dodge Ram 1500.
The story: Was taking a coffee break at work and sitting in my truck listening to the radio. It randomly just shut off.
Tried to restart it and it would just crank and crank and crank.
I got it towed home and started to check the main 3s needed (Air spark fuel)
I have spark on the wires, I have fuel I can hear the pump prime and when I check the fuel rail there is tons of pressure.
After that I checked compression on the cylinders and across the banks Im averaging 120PSI.
In a last shot in the dark I swapped out the ECM on the firewall from a tested used shop and still nothing.
I'm at a total loss of ideas here.
Old Mar 29, 2020 | 11:49 PM
2bit's Avatar
2bit
Crank or cam sensor. Buy Mopar sensors.
Old Mar 29, 2020 | 11:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you scan for codes? And if so what were they.
Old Mar 30, 2020 | 05:15 AM
Kay_tar's Avatar
Kay_tar
I'll start there I guess.
None. Not one stored or active code.
Old Mar 30, 2020 | 08:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can rent noid lights ferrin your local auto parts store. Use then to see if you are getting injector pulse
