Fuel problem
Old Apr 9, 2020 | 07:45 AM
01 should only have one. It's located by the thermostat housing. (I think, might be over on the passenger side by the heater hose as well.) Two-wire sensor. They are known for deteriorating, and falling apart. Then the PCM thinks the engine is (much) colder than it really is, and runs it rich. But, the PCM uses that same sensor for the gauge in the dash..... So, if the gauge is telling you the engine is at the proper temp, it probably is.
Old Apr 9, 2020 | 12:23 PM
01Secondgen's Avatar
01Secondgen
So there is that one and than just the two upstream and down stream ones forward and aft of the cat
Old Apr 9, 2020 | 01:06 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Correct
Old Apr 9, 2020 | 01:39 PM
01Secondgen
Correct
yah this fuel problem is perplexing.
Old Apr 9, 2020 | 04:54 PM
MoparFanatic21
If it's Cali emission you'll have 4 O2 sensors
Old Apr 9, 2020 | 11:21 PM
01Secondgen
nope its built for canada
Old Apr 10, 2020 | 12:17 AM
MoparFanatic21
Then you might not (not sure on Candadian emissions).
Old Apr 10, 2020 | 11:35 PM
01Secondgen
Default Frustrated and still burning crap loads of fuel
here's my issue I am burning an excessive amount of fuel in 68 km i burnt quater of a tank I recently did a mini tune-up change the spark plugs did a seafoam upper engine cleaner change the valve cover gaskets did a seafoam fuel additive which cleans injectors and rails and all that remove the catalytic converter and put on a cherry bomb exhaust still using the same Magnaflow mufflers and I don't know what else to do this fuel problem is ridiculous and I'm wondering if anybody has some ideas of what else I can do to try and fix this problem
Any body else have any ideas .
Old Apr 10, 2020 | 11:45 PM
MoparFanatic21
Could be a tune causing it to dumb to much gas
Old Apr 11, 2020 | 01:03 AM
01Secondgen
I think my best bet at this point is to get it into a shop and have it diagnosed
