Lots of issues after repairs (Engine)
Old Apr 13, 2020 | 07:31 PM
  #21
How old are the plugs/wires/cap/rotor?
Old Apr 13, 2020 | 07:34 PM
  #22
FiveNineMotorsports's Avatar
FiveNineMotorsports
Plugs, cap and rotor are only a few days old. (Swapped them all when I had the motor torn down). Wires are MSD 8.5mm Super Conductor and are a few months old (4-8 months old, not sure exactly how long though)
Old Apr 13, 2020 | 09:51 PM
  #23
What brand plugs? What type? These trucks really don't like the rare-earth plugs..... (platinum, Iridium, et. al.)
Old Apr 14, 2020 | 02:28 AM
  #24
FiveNineMotorsports
I was originally running NGK Iridium, the plugs I just installed are Auto lite copper core 3923
Edit: These plugs were recommend by another user under a thread about the death flash, regarding using them with the hemifever tuner. I was planning on a tuner in the future so I decided to go ahead and make the plug switch now. Plus I have read that they are not fond of the big boy plugs either
This truck has 187k miles on it and it just came to mind that compression could also be a potential cause of the misfire and rev limiter issue. I have also noticed my fuel mileage started to decrease before I even replaced all these parts, and the CEL codes can also results of compression loss. Tomorrow morning I'll go pick up a compression tester kit and get back to yall with the results.
Old Apr 14, 2020 | 08:35 AM
  #25
Done anything with the plenum yet?
If you have an air compressor, I would be more tempted to do a leak down test.
Old Apr 14, 2020 | 12:16 PM
  #26
FiveNineMotorsports
Yes, my plenum was blown so i used Hughes engines repair kit, felpro gaskets and plenty of rtv where required.
And I do have an air compressor so I can run the leak down as well.
Compression tests results still to come
Old Apr 14, 2020 | 07:20 PM
  #27
FiveNineMotorsports
Low compression cylinder 4
Tested cyl 2 dry: 155 psi
Tested cyl 4 dry: 105 psi
Tested cyl 4 wet: 130 psi
Didnt even bother testing the rest of them. Now it's time to figure out what to do. Thanks for all the input lads, much appreciated
Old Apr 14, 2020 | 08:26 PM
  #28
Yeah, that's bad rings. You could try an engine treatment, and see if the rings aren't just stuck, or some such. Worth a shot anyway.
Old Apr 14, 2020 | 08:29 PM
  #29
FiveNineMotorsports
I'll give it a shot and see what happens. Otherwise, shes got 187k and 24 years on the clock, it's about time to pull the motor and rebuild it or swap it for something else anyway
Old Apr 14, 2020 | 08:30 PM
  #30
408 build time?
