Ice Cold
Old Apr 25, 2020 | 01:37 AM
01Secondgen's Avatar
01Secondgen
Default Ice Cold
Can anybody tell me why my 01 2nd gen loves to start when it's freezing cold out I'm talking - 45 degrees Celsius but hates to start in anything above + 5
Old Apr 25, 2020 | 01:53 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I had to cover that to Freedom numbers . That's not that hot. Does your temp gauge work?
Old Apr 25, 2020 | 03:06 PM
01Secondgen
temp gage works great the only problem I have is heavy fuel consumption
Old Apr 25, 2020 | 08:51 PM
MoparFanatic21
Do you know if it reads accurate. If the computer thinks it's colder than it really is it will dump more fuel causing it to flood. Heavy fuel consumption could be a number of things.
Old Apr 25, 2020 | 09:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
Try disconnecting the battery and put the cables back on. I remember when doing the recalls on the durango's the temp gauge would read -40. If the doesn't work try a new temp sensor.
Old Apr 25, 2020 | 10:56 PM
01Secondgen
you guys are miss interpreting the situation my truck starts like a chame in below freezing temps and and turns over 20 times when the temperature is above freezing. Or I miss interpreting what you guys are all saying
Old Apr 26, 2020 | 01:02 AM
MoparFanatic21
That usually is the temp sensor. When it's cold it has to dump more fuel. When it's warmer it down have to. But if the computer thinks it's cold it will flood the engine with fuel.
Old Apr 26, 2020 | 01:22 AM
01Secondgen
ok great I will grab a temp sensor tomorow and see if it helps thanks MoparFanatic21
Old Apr 26, 2020 | 01:24 AM
01Secondgen
and did you mean the engin coolant temp sensor or is there another temp sensor
Old Apr 26, 2020 | 01:41 AM
master tech
Engine coolant temp sensor.
