97 1500 bad tranny
Old May 3, 2020 | 10:21 AM
CodeBlue's Avatar
CodeBlue
Default 97 1500 bad tranny
I have a 97 1500 5.2 with a bad transmission. I am just wondering if a 44RE out of a 96 dakota 5.2 will work until I can get the 46RE rebuilt. I looked at the transmission pinouts and they seem to match. I know it isn't the ideal situation but the 44RE came with the truck and I am trying to save cash in order to get this on the road faster. I know the 44RE is a weaker transmission and will lower the load capacity. But for a temporary fix would it work without additional parts? I plan to use the transfer case from the current transmission.
Old May 3, 2020 | 11:03 AM
Are the transmissions the same length? If they are, it will probably work, though I wouldn't do any heavy work with it.
Old May 3, 2020 | 11:06 AM
CodeBlue's Avatar
CodeBlue
I haven't been able to determine the length from the front of the case to the tail of the OD housing I will probably measure that when I get off work. They both use the same case up to the OD assembly from what I've read. But you know its the internet so I don't believe everything I read lol.
Old May 3, 2020 | 11:07 AM
Smart man.
They are *probably* the same length, but, I would measure it anyway. Don't wanna go thru all the work, only discover that it won't work.
Old May 3, 2020 | 12:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
Your torque converter may not bolt up to the flex plate the the wire connection for the lock up solenoid may not plug in either.
