Popping/clanking/clicking
Old Sep 29, 2020 | 07:46 PM
Originally Posted by Spillage
My knees, elbows, and a bunch of other joints...
Just about all of them...... I have what is know as "Rice Crispy Spine"......
Old Sep 29, 2020 | 10:09 PM
Swoodruff85's Avatar
Swoodruff85
It's a 2wd
Old Sep 30, 2020 | 07:32 AM
Well, not front u-joints then.
If you jack it up, and spin the tires, can you hear the noise?
Old Oct 3, 2020 | 01:24 AM
Swoodruff85
Ok so I have figured out what the mysterious noise is I think. I am almost sure it is coming from differential. Like maybe pinion gear? I do know that my spider gear has a couple teeth broken off it as well. I have t been able to have it confirmed but hearing the noise compared to some of the videos I have watched it is exactly the same. I have a few questions now...
1. Would it be better to replace parts or just get a whole new rear end?
2. Is it dangerous to drive my truck until I have the funds to repair?
3. How much should repairs like that cost?
4. Does it seem like I've found the correct answer?
Any and all help, suggestions, and/or advice is greatly greatly greatly appreciated. Thank you in advance!
Old Oct 3, 2020 | 09:47 AM
If you have broken teeth in there already, it's a ticking time bomb. It may run forever and a day, it may lock up tomorrow..... It's a gamble. If you have something else to drive, leave the truck sit till you fix it.
If *all* it needs is spider gears, that's a relatively easy repair. If it needs more than that, might be cheaper just to replace the entire rear diff.....
