Popping/clanking/clicking
Old May 14, 2020 | 06:28 PM
Swoodruff85's Avatar
Swoodruff85
Default Popping/clanking/clicking
So I have a 2001 2nd generation ram and a few weeks ago when I hit the brake my truck started making a loud clanking noise. (Similar to card in bike wheel spokes but louder) I can also feel the clanking under my feet. It doesn't happen every time so I have no clue where to even start working it out. Any ideas??
Old May 14, 2020 | 06:50 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I had the same issue Turner out to be my axles were moving ever so slightly
Old May 14, 2020 | 10:50 PM
Swoodruff85
so what did you have to do? Is it bad to keep driving as is?
Old May 14, 2020 | 11:07 PM
MoparFanatic21
Depending on what it is it could be fine or not. Mine was loose bolts. You said you feel it under your feet. I wonder if your transmission mount (it's rubber) is bad
Old May 14, 2020 | 11:35 PM
Swoodruff85
Anything is possible I had a transmission put in it about six months ago. I was wondering one thing though is I have a spider gear in the rear differential that has a couple of teeth that had broken off could that possibly be making the noise? However it does seem to be towards the front of the truck when I hear the noise. Also side note, do I have to replace the entire rear end of the truck or can I just replace a spider gear?
Old May 15, 2020 | 12:45 AM
MoparFanatic21
Can replace just the spider gear but I've been driving with 4 missing teeth and 2 chipped on the ring gear for over a year. One member here said there is a TSB for the linkage making noise which would be under your feet
Old May 16, 2020 | 08:38 AM
Moparite's Avatar
Moparite
Could it be the ABS system? You can feel that in the pedal but doesn't make a loud noise. Also is it 4X2 4X4? May pull the wheels and have a look at the breaks. Check wheel bearings u joints etc...
Old Sep 29, 2020 | 06:28 PM
Swoodruff85
Ok so just had wheel bearings changed and clicking noise is still there. Was in some heavy traffic and noticed the noise isn't only when braking. I was coasting in traffic and the click was in rhythm of my speed. I am so lost right now and about ready to just kick and scream!
Old Sep 29, 2020 | 07:21 PM
2 or 4 wheel drive?
Old Sep 29, 2020 | 07:38 PM
Spillage's Avatar
Spillage
My knees, elbows, and a bunch of other joints...
