2001 ram transmission swap
Old May 19, 2020 | 03:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Joeyarsenault92
I tried hooking up my code reader and it wouldnt pick it up I figured it wasent communicating because of the can bus problem
Only scan tool that can do it is an OEM or High Dollar one. If I remember correctly to get the Cluster Codes just hold down the trip button and turn the key on
Old Jun 1, 2020 | 02:14 PM
Joeyarsenault92's Avatar
Joeyarsenault92
I think there's a good chance of that. NTK or Denso sensor only though. Skip Bosch, they tend to cause more problems than you are trying to solve.
I tried putting in a new denso o2 sensor and it seems like it didnt work aswell it ran the same rough idle no power and backfiring when I tried accelerating, might be something a little more hard to diagnose?
Old Jun 1, 2020 | 03:16 PM
Getting any codes? Got a scanner that can read live data? Might wanna see what the various sensors think is going on, and see if those readings bear any resemblance to what you would expect. Check for pending codes as well.
Old Jun 1, 2020 | 03:34 PM
Joeyarsenault92
I do have one of them bluetooth code readers you read off your phone I can get live data off it and it has worked well for me on other vehicles but it wont on the truck for some reason, I'll try getting hold of a good expensive one sometime, thanks heyYou!
Old Jun 1, 2020 | 07:53 PM
MoparFanatic21
Even a cheap $20 Amazon one will get you the basic live data you need
