Towing capacity change a bit?
Old May 18, 2020 | 09:42 PM
96albertaram's Avatar
96albertaram
Yep! Need the 2500 LD pads and calipers and I went with Chevy 1 ton wheel cylinders (even bigger than Dodge). My biggest improvement was Hydroboost
When you say wheel cylinders you mean wheel bearings right? What exactly is hydroboost?
Old May 18, 2020 | 09:48 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Wheel cylinders are for the rear brakes. Hydroboost replaces the vacuum brake assist with one that uses power steering fluid. It gives the brakes more pressure (ALOT more than the vacuum). I stop my 40s with little pressure. It takes about a 1/8th inch press from 65
Old May 18, 2020 | 11:27 PM
96albertaram
That's pretty epic! sounds like alot of work I'm trying not to dump to much money into this truck as I have alot into it already. At this point I could of bought a diesel . I think I will consider the 3/4 ton caliper upgrade though
Old May 19, 2020 | 10:56 AM
MoparFanatic21
I hear you when I swapped the Cummins motor for the 360 it took a big hunk of change
Old May 20, 2020 | 10:02 PM
96albertaram
lol I wish
Old May 21, 2020 | 03:55 PM
MoparFanatic21
lol I wish
What? I did it, went from a diesel to gad wasn't that hard just took lots of $$.
Old May 21, 2020 | 05:33 PM
Solved the problem the American! way... Threw money at it.
Old May 21, 2020 | 06:31 PM
MoparFanatic21
See I ran into a problem. Wait a few days from Parts (Rockauto) but I'm impatient or buy the parts for 3x as much from the two stores . Plus I went overboard so much for $500 "never rust" headers
Old May 21, 2020 | 07:56 PM
96albertaram
haha hey atleast you got bragging rights can say you did it!
Old May 21, 2020 | 09:20 PM
MoparFanatic21
True I always go the path less traveled next is the Hellephant I ordered making it a sleeper!
