Coolant temp sensor issues
So I have a 1998 ram 1500 5.2 auto. My coolant temp gauge is reading low currently. I have replaced the water pump. Thermostate twice now cause it was in my plenium gasket kit. I have tried to replace coolant temp sensor with single pin and double sensor. Both read that it is low. I am also having the issues of rough idle and dying when coming back down in rpms. My idle air control valve seems to b working correctly but have a new one on the way to take that out of the question the truck has a full new tune up i am wondering if anyone has a fix for this or a way to bypass this for the engine to run correctly and just use a store bought gauge thanks in advance
Your truck only has one temp sensor, and both the gauge, and the PCM use it. Need to find out if the sensor is simply mis-reporting, or there is some other issue going on. Check temp with an IR thermometer, and see if the gauge is actually telling the truth. Might also plug in with a scanner, and see what temp the PCM thinks the engine is.
The 98 model year has a sensor with two pins which both connect back to the PCM. As HeyYou wrote the sensor is used for both engine management and the gauge. Below is a table of what the sensor should read at different temperatures. Also consider that bad wiring might cause the PCM to read high resistance which is interpreted as low temperature.
I currently have the double pin sensor hard wired in to the harness that Is sotterd and installed cleanly. Would reversing the wires make a difference to and as for being able to hold the hose that was out of the raditor side so the cool side back into the engine but I also have id say decent heat also to show more that it is up to temp.
Trending Topics
No its totally fine I honestly thought the same thing. I checked the Chilton manual I have from napa and it was in correctly. I just went through and replaced the theromostate with a new one from napa and I gained ground on the temp gauge I'm about half way to 210 with a 195 state. I did test the state before I put it in the truck and checked out ok so I guess I'm still stumped on why I'm not there yet endless its just the cluster is off and my IAC valve is bad
Plug in with a scanner, and see what the PCM thinks engine temp is. (your local parts store should be able to do that for you.) I went from a 96 truck to a 98, and the temp gauge on the 98 reads WAY different than the 96 did. To the point that I thought I had a bad thermostat as well, so, I changed it, only for nothing to be any different.... Plugged in with a scanner, and low and behold, 195 degrees......
